Lampile electrometrice (electrometric valves)
Scris: Dum Noi 27, 2022 12:21 am
Sunt tuburi electronice speciale utilizate la masurarea curentilor extrem de mici, de ordinul pA sau chiar fA (10 la puterea -15 A). In general sunt lampi cu catodul incalzit direct (filament), care merg la tensiune de alimentare scazuta (de ordinul voltilor), astfel incat sa nu se ionizeze gazele reziduale din interior si sa creasca curentul grilei de comanda. Curentul grilei de comanda (G1) este minim la o anumita valoare a tensiunii de negativare (de regula sub 1V). La unele tuburi electrometrice pe G1 se aplica tensiune pozitiva (de ordinul voltilor), are rol de accelerarare a electronilor emisi de catod, respectiv comanda se face cu G2.
https://www.radiomuseum.org/tubes/tube_ck5886.html
https://www.radiomuseum.org/tubes/tube_df703.html
http://www.r-type.org/exhib/aai0273.htm
http://www.r-type.org/exhib/aai0274.htm
http://www.r-type.org/exhib/aaa0719.htm
http://r-type.org/exhib/acf0072.htm
http://www.r-type.org/exhib/aaa0747.htm
http://www.r-type.org/exhib/aaa1229.htm
https://frank.pocnet.net/sheets/074/b/BM10.pdf
http://www.r-type.org/exhib/aab0004.htm
https://frank.pocnet.net/other/Mullard/PD/misc_vlv.pdf
https://bms.isjtr.ro/sheets/129/m/ME1404.pdf
http://lampes-et-tubes.info/em/em001.php?l=e
http://lampes-et-tubes.info/em/em009.php?l=e
https://www.g3ynh.info/valves/var/CV495/index.html
https://www.thevalvepage.com/valvetek/pdfs/electro.pdf
Se utilizeaza in fizica nucleara la masurarea radiatiilor cu camera de ionizare, la detectoare de incendiu, la pH-metre, la teraohmetre, etc.
https://www.testandmeasurementtips.com/ ... atured.jpg
http://www.seekic.com/uploadfile/ic-cir ... 349260.gif
https://en.wikipedia.org/wiki/Ionization_chamber
https://en.wikipedia.org/wiki/Smoke_detector
https://en.wikipedia.org/wiki/Radiation
http://210.212.232.211:8080/jspui/bitst ... le%209.pdf
https://en.wikipedia.org/wiki/PH_meter
https://www.azolifesciences.com/article ... -Work.aspx
https://www.researchgate.net/profile/Ko ... dition.gif
https://www.eeeguide.com/ph-measurement-methods/
https://biokimicroki.com/working-princi ... -ph-meter/
http://www.radanpro.com/Radan2400/TestS ... 0Meter.htm
http://www.ph-meter.info/pH-meter-construction
https://forums.parallax.com/discussion/ ... er-circuit
https://acikders.ankara.edu.tr/pluginfi ... 0meter.pdf
http://www.ohiowea.org/docs/1500_pH_Seminar_Meirose.pdf
Tuburile electrometrice sunt practic insensibile la supratensiunile (pe grila de comanda) generate de sarcinile electrostatice. Este principalul lor avantaj.
In prezent se utilizeaza rar pentru ca rolul lor a fost preluat de tranzistoarele cu efect de camp (in special de MOSFET-uri), care din nefericire se distrug usor. Daca li se protejeaza poarta cu diode picoamperice, creste curentul la intrare cu cel putin trei ordine de marime.
Puteti sa va documentati in privinta dozimetrelor (de amatori) cu camera de ionizare de pe website-ul http://techlib.com/electronics/index.html .
http://techlib.com/science/ionchamber.htm
http://techlib.com/science/ion.html
http://techlib.com/science/ionpage2.html
Utilizarea camerei de ionizare permite detectarea radiatiei alfa, detectoarele Geiger-Muller si cele cu scintilatie fiind sensibile doar la radiatiile beta si gama.
https://ro.wikipedia.org/wiki/Dezintegrare_alfa
https://ro.wikipedia.org/wiki/Contor_Geiger
Daca sunt participanti la acest topic pot sa vin cu precizari suplimentare.
